removing the detachable sissy bar
RE: removing the detachable sissy bar
Look at the black tabs on the back facing side where it mounts to the bike. Put your finger underneath and slide your finger forward, You will feel a gap. The next surface forward can be compressed upward. Do this on both sides of the rear of the sissy bar frame. Now push the top of the black taps forward and the sissybar will rise up a bit as it disengages from the quick disconnect studs. Lift up the back of the sissybar then pull it bacward toward you so the front two mounting points clear their mounting studs. Don't trip while moving backwards. 8-)
Same here. I tried to adjust it a little bit but it didn't ake a difference.
ORIGINAL: tmitchellof PG
I have the detachable sissy bar and didn't have any trouble taking it off. Then I added the locking mechanism and it seems like, once I unlock it, it is always a hassle to remove.
Tom
Tom
No the 2 up detachable mounts are in a different location, heres a photo that'll show you better than i can explane it
http://i110.photobucket.com/albums/n...6747F78C1C.jpg
