"DIY MODS" and TRICKS to SAVE $$$$$$
Old 11-01-2015, 03:05 AM
DALE#3's Avatar
DALE#3
DALE#3 is offline
Originally Posted by motoXjoe
How about turning the cowbell horn (literally) into a rear cylinder cooling device. Just swivel the opening to point forward and voila, rear jug scoop!
Rear cylinder cooling air scoop mod.
I haven't looked at my horn back yet but,Wondering if the horn is open on backside?Did ya have to cut out? Any help to a 110 ci rear is a huge plus.A fan mod hidden would be good for stopped traffic.
  #1802
Old 11-09-2015, 06:32 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
I found some work choice mini work lights at walmart today and for $5/pair I figured they would work out for a good tour pack and saddle bag light. They are magnetic, but i had some left over velcro and just put some velcro on the backs and attached them to the tour pack lining, and the back of the saddle bags.
shezaharley (03-04-2016)
  #1803
Old 11-16-2015, 08:03 AM
egore's Avatar
egore
egore is offline
Stage III
Great idea. I looked on Walmart's site, but couldn't find these. Do you have more info on them so we can find them? Thanks.
  #1804
Old 11-17-2015, 06:13 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
Next time I run into walmart I'll get a picture of them in the package.
  #1805
Old 11-23-2015, 10:43 PM
The Cheesehead's Avatar
The Cheesehead
The Cheesehead is offline
I decided to rewire my garage door opener and LED switch into my dash. The garage button is a h-d part that was a momentary switch-the same as th speedo button and the LED switch is an on/off switch.
  #1806
Old 12-05-2015, 04:39 PM
djamann's Avatar
djamann
djamann is offline
I found the Work Choice lights at Walmart today. Great $5 mod!
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-20151205_172220.jpg
  #1807
Old 12-05-2015, 05:52 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
Yep, those are the ones.
The following 2 users liked this post by TeamMudd:
Proline1969 (12-07-2016), shezaharley (03-04-2016)
  #1808
Old 12-17-2015, 08:13 AM
Sturgis67's Avatar
Sturgis67
Sturgis67 is offline
Looks like these work well on the bullet lights. Has anyone tried them, or know if they work on the big fat lights like on a 2013 ultra classic?
Originally Posted by fphoenix
I'm sure it has been done before but here is a cheap alternative LED light if you don't want to spend $90 on custom dynamic lights. i picked this set up at wal mart for around $12. Slight modification of your tail light assembly is required. nothing that a dremmel can't take care of. Start by removing your old bulb. you will see that the new bulb is slightly bigger than the opening. simply make the hole a little bigger and you have new red LED bulbs that are CAN Bus so they will work properly.
  #1809
Old 12-21-2015, 03:05 PM
egore's Avatar
egore
egore is offline
Stage III
Found them. Thank you!
  #1810
Old 12-26-2015, 09:08 PM
terryrh's Avatar
terryrh
terryrh is offline
This is a must do! Thanks.
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
