"DIY MODS" and TRICKS to SAVE $$$$$$
#1861
Made my own breather bolts using 3/8"-16 all thread rod cut to needed length and chucked in hand drill with bit mounted in vise. The reason for making my own is Arlen Ness Big Sucker intakes exit internal and I dont want to drill and tap the intake and the stock bolts are too short and no one makes a length long enough. (2 3/4" total length here)
This way I can remove their internal exit breather bolts, insert rod as a hollow stud and secure with chrome washer and nut and tubing secured to rod end or add a 90 degree fitting to a barb and then plumb both sides to a T and then down to the ground via breather filter. Just another way to accomplish what others are doing with kits but home made.
crazytown (05-08-2016)
#1862
If I can do it, you can! Posted a couple pics with run and brakes applied. Nothing earth shattering, but it is a little better to have all lights go bright when brakes are applied.
#1863
#1864
I wanted to use hollow threaded lamp rod that is common but not in size I needed. That may have worked in your case but nothing beats solving problems in your own ways!
#1865
Yeah, but I wanted ss, no rust, since it mounted to chrome fender struts and the threads were not typical.
#1867
#1868
Thats easy for me, i took an old remote i had and used super strong double sided tape and taped it to the under side of the mid frame air deflector so no one knows that its there but me.Just pull into the driveway reach down beside my leg and push the button, easy peasy!!
jyd83 (08-07-2021)
#1870
