Don't have primary drive locking tool, any else work
12-27-2007, 05:09 PM
Going to check compensator nut this weekend and don't have the locking tool, I've seen and read about ways around this but I can't find it in the forum. anybody used an alternative method that worked OK? Thanks, Tim
12-27-2007, 05:21 PM
RE: Don't have primary drive locking tool, any else work
I've used to 2, 1/2 inch bolts with the heads positioned into the teeth of the gear. I just reversed them when I tightened the nut.
12-27-2007, 05:25 PM
You can make your own out of a piece of flat bar. I can dig up the dimensions if you need them.
12-27-2007, 05:27 PM
Found it on Harley Hogs website, thanks to HH
12-27-2007, 07:17 PM
screwdriver handle works too.
12-27-2007, 07:30 PM
Block of hardwood will work
12-28-2007, 06:34 AM
Thank's guys, I've wondered if something like the handle of a screwdriver like a Mac or Snap-on would hold up. I'll give that a try first. Tim
12-28-2007, 06:45 AM
When I installed a chrome inner primary on my 06 Dyna I just used an air impact wrench to remove it and I adjusted the torque setting to match what was the recommended torque when I reinstalled it.
12-28-2007, 06:46 AM
Quote:
ORIGINAL: Dalton
i second that...
12-28-2007, 05:55 PM
Ball up a shop rag, if your primary chain is tight enough it works great and wont hurt anything.
