Removing Scratches
RE: Removing Scratches
After doing some pretty in-depth research, I bought a Porter Cable 7424 buffer. I use Meguires speed glaze 80.
If you aren't familiar with these, you can do your own research by searching the web. I think you will find that this is probably the best way for a home-user to get scratches out of paint. Yes, it will cost you some money but I can tell you that this buffer is the #1 choice for detailing at home.
You can also try Scratch X by hand. I'll warn you now that it can be a huge amount of work by hand and the results will be mixed.
I have 2 black bikes, a black truck, and 2 dark blue cars. It would be impossible to maintain them by hand. The PC buffer is the ONLY way to go. Spend some time searching the web and you will find out for yourself.
Concerning my black bikes . . . for some reason they seem to be magnets for light scratches. I'm a picky person and I take care of my bikes. I know how to wash them and I blow them dry . . . but they still get light scratches. I don't know if it's the type of clearcoat HD uses or what. Have you noticed the same thing??? Anyone else??? Maybe it's just me.
Hope this helps.
Steve L.
Hope this helps.
Steve L.
PC 7424 +1
I use Lakeside orange pad & lazer buff by poor boys for mod to heavy scratches sometimes wet sand
Light poor boys for lighter scratches
Check car detail forums for best ways and products. I have dark vehicles so learning how to buff out light scuffs and paint transfer from people dinging my doors was a must.
buffer gets best results
Hand is ok have had ok luck with scratch X
Steve, I here you on the fine scratches and HD black paint. I buff major stuff as it comes up (wife's boot mark on a saddle bag lid) other than that I just wash and use Griot's paint sealer and it hides light scratches. Then once a year I give the bike a good wash, clay, buff, wax.
if they are scratches that are deep but not into the paint you can "color sand" the clear with 1200 grit wetsand paper.Then buff with your basic electric grinder/buffer using an "egg crate" type foam pad and 3M micro polish. Do not apply too much pressure and only long enough to polish the dull surface created by sanding with the 1200 grit paper.
This should be in the detail section, I think, and there is more info there about scratches and what-not.
I been trying to learn about keeping black paint nice too. I'm leaning toward trying some pads and polishes by hand first. There's not much room for a polisher and I'm afraid I might mess up and create a big problem. Eventually I might get some small pads, like Orange Country, and try them by hand. I think the pads can be as important as the polish??
