Where to tie down a ultra when trailering long distances
Old 01-19-2008, 07:54 PM
singlepin's Avatar
singlepin
singlepin is offline
Default RE: Where to tie down a ultra when trailering long distances
this is how mine came from the factory, just 2 straps to the crash bars
[IMG]local://upfiles/46021/F5E04D4EFEB2487792337D24CF85F55B.jpg[/IMG]
Old 01-19-2008, 08:26 PM
SteveO's Avatar
SteveO
SteveO is offline
I trailer my bike about 10,000 miles year for the past several years.
Don't strap your bike down using the handle bars or front struts at the axle, you need to keep the entire bike from moving up and down. This up and down movement without a rider will damage the suspension. The bike needs to be secured into a heavy duty wheel chock
Here is how I strapmy Ultradown as recommended by Harley and numerous trailer manufacturers.
I have a 12' enclosed Featherlite motorcycle trailer.I use a bike-pro wheel chock. Tie down both sides in front using hog ties and rarchet straps. I tie the hog ties around the triple tree across the crash bar and hook the ratchet strap to the hog tie on each side, snug it down good, you don't want any up and down movement in the front end. If the bike is allowed to move up and down it will damage something, or a strap will come loose. No......you won't damage the front suspension by cranking down good and snug, about half way or just before it bottoms out.!! You will damage it if it is allowed to move while trailering.
In the rear I attach the ratchet straps directly to the reat passenger foot rest, snug enough to keep the rear end from bouncing and the bike from moving forward.
I use an additional set of straps attached to the front foot rest and tie down on the rear trailer tie downs. This will keep the bike out of your car if you hit something.
See enclosed trailering article: http://www.chariot-trailer.com/index...&Itemid=43
Hope this helps.
Steve
Old 01-19-2008, 08:37 PM
Mullenix53's Avatar
Mullenix53
Mullenix53 is offline
There were six of us went out to Sturgis in 06.
I wouldn't make that trip with out a chase truck for the God forbids. Thank God we didn't have any.
Everyone was thankful I insisted on taking my truck and trailer for extra haulings though.
You think anyone volunteered to share the driving?[:@]
For that reason, my bike E. Glide classic got trailered both ways.
I soft tie'd around the lower triple tree on the front and the crash bars in front of the bags on the rear.
One thing to watch out for, even with soft ties on the front, I guess because of the long distance, even the soft ties left marks in the aluminum upper slider on my front forks. So be careful and certain of what you wrap around what to tie down with. If it is up to me in the future, I'll ride everywhere I go.
Old 01-19-2008, 08:50 PM
ApeKing's Avatar
ApeKing
ApeKing is offline
[sm=icon_quiet.gif]
Old 01-19-2008, 09:45 PM
Neckball's Avatar
Neckball
Neckball is offline
How does the motorcycle know whether there is a rider on it or not? I thought suspension was designed with up and down movement in mind.
Old 01-19-2008, 10:54 PM
motorcyclerescue's Avatar
motorcyclerescue
motorcyclerescue is offline
Front wheel in chock, 2 Racheting straps on crash bar pulling down & out,
2 straps on rear foot pegs pulling down & out.
just check every 200 miles or so you'll be fine
David
Motorcycle Rescue Inc.
Motorcycle Towing & Transportation
Old 01-19-2008, 11:23 PM
capt42a's Avatar
capt42a
capt42a is offline
This is the method I've used.
capt42a
ORIGINAL: soos
This is how I do it. Ratchet straps only, no cam locks. All straps pulling forward into wheel chock and no strap higher than the passenger footboard bracket.
[IMG]local://upfiles/4575/C2B93F14754F49E5B52434602C73C3E6.jpg[/IMG]
[IMG]local://upfiles/4575/3FC48641B9B34E88BE0C1C2CC9CDFD76.jpg[/IMG]
[IMG]local://upfiles/4575/BD69E15FA34847689B95D5008DD9CD08.jpg[/IMG]
[IMG]local://upfiles/4575/CB79D36DE87A4E578F187F7591B015FE.jpg[/IMG]
[IMG]local://upfiles/4575/6BF4C032B8354B7A9633B4FA0333C6D1.jpg[/IMG]
Old 01-19-2008, 11:53 PM
wolfjack's Avatar
wolfjack
wolfjack is offline
I have hauled my EG many miles without any problems. I tied as dealer suggested . Front crash bars each side and rear crash bars in front of saddle bags using wheel chock, rachet straps and soft ties...Never should you tie to handle bars according to dealer...
Old 01-20-2008, 02:12 AM
mike5511's Avatar
mike5511
mike5511 is offline
ORIGINAL: SteveO
Hope this helps.
Steve
Hmmmm.....according to "Singlepin's" pic, somebody needs to tell the factory about this suspension thing.
I use two straps around forks where fender attaches and pull straight forward into chock, two straps offframe near triple tree straight out and down (about 45 degree angle). two straps off pass. floorboards pulled back (compression straps are fine for the back).....soft ties everywhere.
I use one set of 2"Big Daddy's off the frame and less expensive straps everywhere else. The ones off the frame keepit upright and receive the most stress, the others justkeep itfrom movingback andforth. Check out Big Daddy's straps herehttp://www.pingelonline.com/tie_downs.htm
I have hauled one several thousand miles this way on several different occasions, in a couple of different trailers, and the bike has yet to move! (I really believe the two Big Daddy straps would hold it all by themselves, even through an accident....and no, I have not been paid to advertise for Big Daddy, nor do I know anyone associated with them.....I do know a great product when I see one!)
Old 01-20-2008, 01:27 PM
jsimo7's Avatar
jsimo7
jsimo7 is offline
thanks for the info
Quick Reply: Where to tie down a ultra when trailering long distances
