Opinions on Heat Demon's with Iso Grips
Old 01-20-2008, 12:38 PM
gilbos440rt's Avatar
gilbos440rt
gilbos440rt is offline
Default Opinions on Heat Demon's with Iso Grips
Has anyone used the Heat Demons with a set Iso Grips, getting ready to change bar's and my Harley heated grips still work great but sorta have a melted look to them now [:@]I have a new set of Iso Grips to put on, but would really like to keep the heated grips, Heated Gloves are hard for me to put on if not impossible because of two of my fingers being sorta messed up in a motorcyle wreck in the 80's [&o]so heat grips and hippo hands will have to do. So if anyone has this combo what do you think about it, and would your recomend them?
Old 01-20-2008, 06:41 PM
steelhead's Avatar
steelhead
steelhead is offline
Default RE: Opinions on Heat Demon's with Iso Grips
I can't speak to teh Heat Demons butI've been runningIso grips with the Aerostich grip heaters since last spring. These are the kind where the element wraps around the bar. After some trial and error, I installed the throttle side inside the bar. Bottom line is they work fine and so far, no problems at all.
Old 01-21-2008, 08:06 AM
kurtlange's Avatar
kurtlange
kurtlange is offline
i'm using the heat demons inside hd's nostalgic grip. on 3-4, the grips get hot enough to be uncomfortable on a >40* day.
Old 01-21-2008, 08:41 PM
gilbos440rt
Thanks guys that was what I was wanting to know, hard to wrap my mind around the fact that something inside your bars could heat up thru the Iso grips enough to work
apetterez
01-15-2015 05:10 PM
joyryd68
09-22-2013 03:23 PM
bshughes657
03-02-2013 01:11 PM
SinCityJets
08-31-2011 09:20 AM
steelerdude1
11-27-2010 10:09 AM
Quick Reply: Opinions on Heat Demon's with Iso Grips
