Online Parts Microfiche
Old 03-30-2011, 10:42 AM
jhsledhed's Avatar
jhsledhed
jhsledhed is offline
Unhappy Great but...
Originally Posted by pwp
Try this one, from "Ronnie's H-D"...
http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
Is that what you had in mind?
Great but... No Part numbers!
Old 03-30-2011, 10:46 AM
Mike T's Avatar
Mike T
Mike T is offline
Select the part, go to check-out, but don't buy. It will show you the part#.
Old 03-30-2011, 11:01 AM
atrain68's Avatar
atrain68
atrain68 is offline
Originally Posted by Usmarco
Bandit has microfiche for harleys up to 2002. http://www.bikebandit.com
Unfortunately the part #'s are not OEM, you can go thru the drawings and use as a reference.
This is the best legal way to get online parts info, but you are right, Bike Bandit does not post OEM part numbers. IMHO, purchasing both a service manual and a parts manual are an indispensible resource to have on the shelf. I am not a fan of the bootleg stuff floating around.
Old 05-02-2011, 01:26 PM
mca1989's Avatar
mca1989
mca1989 is offline
Old 05-02-2011, 01:49 PM
ShortBus453's Avatar
ShortBus453
ShortBus453 is offline
I thought that I had an answer for you to try without the "List"......but here is another site for OEM HD parts.
http://www.kutterharleyonlinestore.c...partfinder.htm
They also haven't updated the list for the '11 models yet.
Old 05-30-2011, 02:12 PM
scoots777's Avatar
scoots777
scoots777 is offline
Stage III
On my ultra the headlight bezel is loose. There is a spring in there but does not hold tight. The tab on the top of the headlight hooks behind the spring and the screw on the bottom holds it in place. Is that all there is to it?
Old 05-30-2011, 02:26 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,547 Likes on 3,057 Posts
Michael, You have to go to the New Members area and introduce yourself to the forum. People might help you from there.
Old 05-30-2011, 06:04 PM
hockey8787's Avatar
hockey8787
hockey8787 is offline
Yes thats all!!
Old 05-30-2011, 07:18 PM
Ole T Sport's Avatar
Ole T Sport
Ole T Sport is offline
Welcome to the Forum Scoots
Old 06-03-2011, 09:43 AM
strtarrow's Avatar
strtarrow
strtarrow is offline
I found this and hopefully it is not violating any copyright rules. Does have part numbers, just not sure about model years.
http://www.who-sells-it.com/images/c.../pdf_21093.pdf
Quick Reply: Online Parts Microfiche
