Setting the clock
Old 02-04-2008, 09:47 AM
mattman22033's Avatar
mattman22033
mattman22033 is offline
Default Setting the clock
It is a 2006 HK radio. YesI read the manual...LOL
This might be a dealer fix...ugh. ButI though I would ask here first. My clock setting seems to be stuck. I press the set button and on the screen it shows:
Time Set
DST ON
New Foundland (this has arrows pointing up& down on either side)
I cannot do anything else...it seems to be stuck. The clock is about 13 minutes fast which is no big deal but I would like to set it to the correct time. All the rest of fucntions on the radio work correctly.
Last Friday Iput 2 pig tails on the battery. One for the battery tender and the other for my heated vest. Could this have caused an issue with the clock setting function??? I have set the time before so this seems odd. Is there a reset button somewhere. I looked through the owners manual and found nothing to help me.
The bike is still under the 2 year warranty so if I have to have the dealer fix it so be it.
Any suggestions? Thanks in advance.
Old 02-04-2008, 12:32 PM
mattman22033
Default RE: Setting the clock
Damn...no one has any suggestions...guess the dealer it is.
Old 02-04-2008, 12:39 PM
Amodump001's Avatar
Amodump001
Amodump001 is offline
I just did the same thing but didn’t check the clock. I found nothing in the manual either, I have changed it a number of times but never can remember, just work at it. Sorry I couldn’t help, next time I set it, will take notes.
Old 02-04-2008, 12:43 PM
Amodump001's Avatar
Amodump001
That’s strange, I managed to put the pigtails in without losing the time. I must be fast. Oh well, your on your own.
Old 02-04-2008, 12:52 PM
outlaw0013's Avatar
outlaw0013
outlaw0013 is offline
Checked and there's nothing about it in the service manual either.
Old 02-04-2008, 01:03 PM
Amodump001's Avatar
Amodump001
I think (??) you have to have the accessory switch on with the radio off.
Old 02-04-2008, 01:09 PM
Doug45601's Avatar
Doug45601
Doug45601 is offline
The radio should hold a charge that will maintain radio settings and clock settings for a short while during battery work.. Once the battery is reconnected you should be good to go but if too much time has passed you may need to discharge the radio so you can reset it. Find the fuse for the radio... or plug and disconnect it... then hold down the power-on button on the radio for at lest 10 seconds... release the button, reconnect the plug or put the fuse back in... powerup the bike electrical system and try again.
Old 02-04-2008, 01:38 PM
outlaw0013's Avatar
outlaw0013
If what Doug said doesn't work try going to Hawg-Wired.com. They might be able to help if all else fails.
Old 02-04-2008, 01:43 PM
ironhorse's Avatar
ironhorse
ironhorse is offline
The display showing New Foundland is what caught my eye. Mine did the same thine 3 days after leaving the dealership. They couldn't figure it out either. I unplugged the battery for about 10 mins. and then it was able to be reset.
IronHorse
Old 01-13-2013, 05:43 PM
Ratchet2012's Avatar
Ratchet2012
Ratchet2012 is offline
Default Power Button
Same thing happened to me after installing heat demons. I have the on board GPS so I brought it up thinking it needed to update the location . . . nope . . . still stuck . . . 20 mins later, I'm back out there after reading this thread and held the power button for probably 30 seconds. STILL said the "New Foundland" crap . . . 20 mins after THAT, I met some friends to go ride in the mountains. I was fussin and cussin and turned the acc on and SHAZAM . . . Eastern time . . . turnd off DST and the correct time popped up . . . Not sure if it was the whole GPS thing or the power button trick that did it but I'm leaning toward the Power Button . . .
Quick Reply: Setting the clock
