Discount Ramps
Discount Ramps
Have any of you used any of the ramps at: http://www.discountramps.com/
I'm looking for an easy way to load a 2007 Street Glide into the back of an F-150.
Thanks
Thanks
RE: Discount Ramps
I bought mine from them six years ago to load an Ultra in an F-350 4X4. As you can see in the pic, I welded a piece of solid diamond plate on the center section. Made it a whole lot easier driving up the ramp. Smooth and not the bump, bump, bump from the rails. Mine are 12 foot, three sections that fold in half. I think the new ones have a pin to take them apart. Make sure you remove the tailgate, or you might dent it. Secure the ramps to each other, and to the back of the truck.
[IMG]local://upfiles/30204/C4AE102FFD8E4068A755DA61AB689863.jpg[/IMG]
RE: Discount Ramps
ORIGINAL: bdavis
Thanks
Thanks
RE: Discount Ramps
Make dang sure you hook/chain/tie/strap the ramp to the truck. If you have to motor the bike up the ramp, the rear wheel can kick the ramp out from under the bike. It happened to me once when I was riding my 03 Lowrider up a ramp into my utility trailor. At the top of the ramp, the bike stopped (didn't want to run into the front of my trailor). I gve it a little too much throttle and the rear wheel shot the ramp out from under me and the bike. Luckily the bike sat down on its frame and didn't crunch me. Could have been worse. Nearly messed up my britches, though.
To solve that problem, I drilled a couple holes through the top of the ramp and the rear of my trailor. Then I just dropped two bolts through the ramp holes, into the trailor holes and it never happened again. If you're gonna use your truck, you need to find someway to attach the ramp to the truck before going up it.
Just a caution.
Hack
Just a caution.
Hack
