Reflector removal from bag latches
RE: Reflector removal from bag latches
Heat is the key. If you use anything metal to pry, wrap it with masking tape or a rag. Things slip and things get hurt. A scratch in chrome can not easilybe fixed. A cut in your palm will hurt bad.
Also, there was a forum member on here the other day looking for a pair of removed bag latch reflectors (intact, unbroken) to use fora template. Maybe you can post up when you finish to see if he still needs them?
ORIGINAL: mvinc01
