Auxiliary Lights on Street Glide
Old 02-28-2008, 11:06 AM
TampaJim's Avatar
TampaJim
TampaJim is offline
Default RE: Auxiliry Lights on Street Glide
If you are looking for a real clean stealth look, Motolights is the way to go. Variety of finishes available, they mount down low on the calipers and put out a ton of light.
I have been using them for four years and I'm very satisfied.
http://motolight.com/
  #32
Old 02-28-2008, 11:39 AM
Scootr's Avatar
Scootr
Scootr is offline
ORIGINAL: ftlee20723
Aren't there detailed directions for doing this installation yourself? I cannot find them.
Thanks,
Frank
https://www.hdforums.com/m_1315830/tm.htm
Post #3 by Coolnight. I followed these and had no problems with the install.
  #33
Old 02-28-2008, 11:53 AM
outlaw0013's Avatar
outlaw0013
outlaw0013 is offline
If you're looking for a cheaper way to get more light and keep the stock look just change out the H-4 bulb in the headlight. They come in different wattage. Stock is 55/60 and you can get 80/100. Amp draw is not that bad only 2 to 3 amp difference. Check out the Sylvania 9003 bulbs at the auto parts store also $20 bucks compared to a couple hundred for hid change out.
  #34
Old 02-28-2008, 12:03 PM
cwilks's Avatar
cwilks
cwilks is offline
Don't like the look on a SG.....makes it look too much like a regular EG from the front to me....I don't have a problem with the light from the headlight alone
  #35
Old 02-28-2008, 12:33 PM
rebels1's Avatar
rebels1
rebels1 is offline
Location: Pensacola Florida ,Home Of the Blue Angels!!!
can you get the 80/100 watt bulb from Harley ? If not where would you suggest? I am wantingto replace the one that came stock on my 07 streetbob.
Thanks!!!
  #36
Old 02-28-2008, 02:54 PM
outlaw0013's Avatar
outlaw0013
Don't know if the dealer has them. There are a number of places you can get them. One place you can go is J&P cycles. Part #380-887 goes for $16. Don't go any higher wattage. There is any a couple of amp difference between this and stock bulb. I'm getting ready to do this myself.
  #37
Old 03-01-2008, 05:31 AM
IdaSpudSG's Avatar
IdaSpudSG
IdaSpudSG is offline
Default RE: Auxiliary Lights on Street Glide
Glad to have been helpful in your future look.
  #38
Old 03-01-2008, 05:58 AM
fastony's Avatar
fastony
fastony is offline
Don't like them.....Looks like an Electra Glide Standard with them. I put small 50wspots down low ,theydon't take away from the clean look of the Street Glide. You can see them night and day
  #39
Old 03-01-2008, 08:34 AM
zenwee's Avatar
zenwee
zenwee is offline
I Did!
  #40
Old 03-01-2008, 08:57 AM
Abnmarine's Avatar
Abnmarine
Abnmarine is offline
Another one here. I like your trim rings and might look into getting a set.
Quick Reply: Auxiliary Lights on Street Glide
