Can someone post a picture or point me to a link that shows where the power leads are behind the light in the fairing? They are the leads that alot of people use for the Zumo.
Here you go. The two wires exit the headlight power harness and are easy to see. I believe they were female spades (easy, boys!). One is positive and one is negative. I powered my Zumo there for a while. Now I run it to the battery for other reasons. But in this photo, I am using the spades (taped-up and you can't see them) to power the Zumo when the switch is turned on.
