5th Gear Whine
RE: 5th Gear Whine
08's came with the IDS installed from the factory, which should have helped tremendously with the whine we '07 users had to put up with.
But yes...that whine was "normal" starting with the 07's, which is why the moco introduced the IDS "upgrade" for us, while including it on the 08's from the factory.
Solution: Louder pipes and crank up the tunes. Hey...you have a radio after all, ya know?
RE: 5th Gear Whine
ORIGINAL: Phurion
I recently purchased my 07 Ultra Classic and it definitely has the 5th gear whine,whereas I never noticed it in my 07 Softail Custom. What is this IDS upgrade you mentioned? Is it covered under warranty?
Thanks
RE: 5th Gear Whine
Change your trans fluid to something like Amsoil Severe Gear or Redline Shockproof. Makes a noticable difference.
As far as the IDS, it's basically a rubber mounted read sprocket modification. The 08's have it stock and it can be added to the 07's if you want to smooth things out. I don't have it. Don't think I really need it.
RE: 5th Gear Whine
ORIGINAL: 300potato
Thanks
ORIGINAL: Phurion
Thanks
It's not covered under warranty, but it was on the "Elbow Grease" program for a discount on the labor to install it. You can get the IDS itself cheaper from Chicago HD and/or Zanotti's.
I had it installed on my 07 a few months ago and wish I'd done it sooner. The shift between gears is noticeably smoother. No more loud clunking during shifting. I never had the 5th gear whine (not that I could tell anyway...louder pipes + radio ya know =), but the other benefits made it well worth the cost, imho.
