Tour Pack Quick Disconnect Kit
Old 03-13-2008, 07:29 PM
Harley58's Avatar
Harley58
Harley58 is offline
Default Tour Pack Quick Disconnect Kit
A friend of mine is buying a new Ultra Classic. He wants to be able to take the tour pack off when not going on long distance trips. The dealership wants $500. for the quick disconnect kit. I say that is way to much. There can't be much to that kit. Suggestions. Is there anybody out there that sells a after market kit. What all is in the kit?
Thanks.
Mike
Old 03-13-2008, 07:47 PM
tpseabird's Avatar
tpseabird
tpseabird is offline
Default RE: Tour Pack Quick Disconnect Kit
I just bought the kit from Chicago Harley. I paid no where near $500. I had my order in about a week and it took me about 2HRS to install (I took my time). Here are the parts I ordered to make the tour pak detachable. If your friend plans on having a sissy bar or doing a one-up tour pak mount, he/she will need to get the front docking hardware kit (Part# 53803-06). The light plugs, antenna, CB, and speaker wires disconnect very easy and can be hidden under the seat. It takes about 15MINS to switch between two-up and solo(wire connects/disconnects slow things down).
1 x 53276-04 = $143.96
1 x 53804-06 = $43.96
TP
Old 03-13-2008, 07:53 PM
skltr's Avatar
skltr
skltr is offline
With the parts markup and labor the ~$500 tag is not that far out of range
Old 03-13-2008, 07:58 PM
jsimo7's Avatar
jsimo7
jsimo7 is offline
You will need the docking hardware, a license plate kit, and a tour pak rack that attaches to the tour pak. Then you need a rack for your garage to put the tour pak when it's off the bike. About 40.00 for the docking kit about 60.00 for the license plate kit and about 140.00 for the rack thatgoes on the tour pak, and whatever you decide to do for storage when removed. Its pretty easy to install yourself
Old 03-13-2008, 08:01 PM
surfgermany's Avatar
surfgermany
surfgermany is offline
I did this last fall (added a tour pak to my road king) used the kits listed above by tpseabird for about 175 $ took about 3 hours while watching the deadskins lose on tv in the garage.
Old 03-13-2008, 08:06 PM
Bluerose
Guest
Posts: n/a
My dealer quoted $900 to do mine.The parts were about $300 Hubby did the rest....I also havethe CB antenna setup in case I want to use it when the pak is off.
Old 03-13-2008, 09:50 PM
tpseabird's Avatar
tpseabird
I forgot about the license plate and garage rack. I went with the laydown mount by Haulen ***; fit and finish was perfect and it cost under $30. They are listed as one of the "New Vendors" on the site.
Old 03-13-2008, 10:37 PM
99igor's Avatar
99igor
99igor is offline
Here is a link to what I purchased. I also had to get the docking hardware kit and I think one other bracket to make it all work.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 09-15-2008, 03:04 PM
SGT Coffey's Avatar
SGT Coffey
SGT Coffey is offline
6th Gear
Default Removable Tour Pack Info
I myself have an Ultra Clasic and would like to find a kit to be able to remove the trunk and put on a back rest when just going around town. If and when you find anything out please let me know. I have been looking at other sites and they list relocation kits but not sure what all I would need.
Thanks and have an ARMY STRONG day
Michael
Old 09-15-2008, 04:59 PM
gilbos440rt's Avatar
gilbos440rt
gilbos440rt is offline
Being able to remove it at will is a very nice option for sure, not that hard to do yourself either
Quick Reply: Tour Pack Quick Disconnect Kit
