I just installed the true track bike feels alot better more stable but is there a proper way to adjust it .I made the turn buckle loose then turned back to just snug then a quarter turn more is that it?? thanks kully
the instructions say not to disassemble! had to looseing up the stabilizer link to install so how pressure do you put on it ,leave loose make snug or what
Ditto on neutral. Loosen the jam nuts, adjust the center nut left till you feel resistance, then right till you fill resistance, then set it in the middle of the the two.
