Auxliary Passing Lamp Adjustment
Does anyone have the instructions from the service manual about how to adjust the new auxilary passing lamps for a 2008 Street Glide? I have the instructions for these but it refers to the service manual for adjustment which I have on order. I need to know how to adjust them up and down and side to side to keep from getting flashed by cagers. Does if take a special wrench?
Thanks for your input.
RE: Auxliary Passing Lamp Adjustment
Getting Flashed isn't a bad thing is it???? I too get flashed often....was going to do some adjusting, but figured...heck, at least they see me!!...as little night riding as I do, I'm gonna remain highly visible.
Take it to the dealer....let them F@#k with it.... Ride Safe!!
i adjusted mine, whata pita. took an old 9/16 deep socket cut 3/8 slot down the side with die grinder i guess a dremil will work. after getting the light loose lined everything up with thelow beam on garage door tightening the nut without movingchanging the adjustment was the tricky part. results were very good H3 55W blue bulbs are very bright but the adjustment keep flashing to a minumum. good luck
