Mobil 1 75w90 Gear Lube
Old 04-14-2008, 04:11 PM
swicegk's Avatar
swicegk
swicegk is offline
Default Mobil 1 75w90 Gear Lube
Forgive me if this is a stupid question but just did my 1,000 mile service this week end and switched to Mobil 1 V-twin 20w50 for engine and primary and Mobil 1 75w90 gear lubefor the tranny. The gear lube seemed very thin compared to the 20w50, I thought it would be thicker. Am I missing something?
Old 04-14-2008, 04:27 PM
cardboard's Avatar
cardboard
cardboard is offline
Default RE: Mobil 1 75w90 Gear Lube
Synthetic oil seems thinner than dino oil.
I use MCV 20-50 amsoil in my motor and primary and went with the SVO 75-140 in the transmission.
Old 04-14-2008, 04:29 PM
lovette's Avatar
lovette
lovette is offline
6th Gear
Gear lube viscosity numbers don't equal motor oil viscosity numbers. Just from eyeballing it, 70W90 gear oil is probably closer to 30 or 40 weight motor oil.
Old 04-14-2008, 04:43 PM
SG 1's Avatar
SG 1
SG 1 is offline
The 75/140 Mobile 1 worked better in mine. It just feels smoother. I'm running 75/90 now, but I will be changing back.
Old 04-14-2008, 06:53 PM
scaires as hell's Avatar
scaires as hell
scaires as hell is offline
ORIGINAL: cardboard
Why did you feel you had to go 75-140 over 75-90 in your trans? I use 75-90 amsoil in my 08 sg and it seams plenty thick.
Ride On!!!
Old 04-14-2008, 07:07 PM
rjgraham's Avatar
rjgraham
rjgraham is offline
I used 75-90 in my dyna........ not enough miles to change yet on the SG
Old 04-14-2008, 07:12 PM
flhrs07's Avatar
flhrs07
flhrs07 is offline
After lots of research, I plan to run:
Engine - Mobil1 20w50 vtwin (if can find vtwin)
Tranny - Mobil1 75/90
Primary - HD Formula+
Old 04-14-2008, 07:23 PM
Mississippi Bagger's Avatar
Mississippi Bagger
Mississippi Bagger is offline
I'm running the Redline Heavy Shockproof gear oil in my trans and it is by far the best of all the syns I have tried, including the Mobil 1.
Old 04-14-2008, 07:50 PM
SteveO's Avatar
SteveO
SteveO is offline
90W-140 is used in 80,000 GVW 18 wheel trucks....what kind of load are you hauling to need that kind of gear lube?
Seems a little extreme for a 1000 pound motorcycle, don't remember seeing that in my HD manual.
Why don't you guys that feel you need to use this high viscosity lube just pack the tranny with grease like boat wheel bearings?
What the heck does HD know, they just build the bikes!
Old 04-14-2008, 07:55 PM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
Does synthetic in the tranny make the ride feel smoother than dino?
Quick Reply: Mobil 1 75w90 Gear Lube
