removing street glide tank emblems
Old 02-12-2006, 06:39 PM
motor12's Avatar
motor12
motor12 is offline
6th Gear
Default removing street glide tank emblems
i want to remove the tank emblems on my street glide and replace them with an older style harley emblem. my question is how do i remove the emblem without destroying the paint also when i remove them does the paint look good enough to go without emblems if i decide i like the no emblem look ? thanks
Old 02-12-2006, 07:19 PM
blowe's Avatar
blowe
blowe is offline
Default RE: removing street glide tank emblems
I believe those are held on by double sided tape.
Should be able to remove them with dental floss and a blow dryer.
Paint underneath should be fine.
Old 02-12-2006, 08:04 PM
Shift_4lo's Avatar
Shift_4lo
Shift_4lo is offline
Use a hair dyer to warm it up then use dental floss(but i like to use fishing line if you have it lying around) and cut it off and you will have a lot of residue still on the paint and just use either goo gone or goof off to get it off (BTW i think goof off works a lot better but if you have goo gone it works just fine) and i have used theory to take all the reflectors off my bike and it works fine but you will need to wax the bike after because the paint may be a slitly darker color or it may not.
Old 02-12-2006, 11:15 PM
2006streetglide's Avatar
2006streetglide
2006streetglide is offline
I concur with the Fishing Line and Hair Dryer process. I removed mine and unfortunatly they didn't come off in one piece but it didn't matter to me; I had no use for them anyway afterwards.
I thought twice about putting emblems on my bike again because the "All Black" tank looked sweet but I had already purchased the new tank emblems and was obligated to use them.
If I had to do it again I'd leave the tank naked. I think it gives the bike a cleaner look IMHO.
[IMG]local://upfiles/5541/D0CCF17995DE48F2A62B1EA4CDA07E41.jpg[/IMG]
Old 02-13-2006, 02:38 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
the new emblems go good with the rest of your stuff
Old 02-13-2006, 12:16 PM
CHEYENNE's Avatar
CHEYENNE
CHEYENNE is offline
Fishline/Dryer
If you don't screw them up may be able to sell on Ebay.
Old 04-19-2006, 03:55 PM
jsm562's Avatar
jsm562
jsm562 is offline
Before I attempt this and ruin my paint, how exactly is the floss/fishing line used in conjunction with the hair dryer to remove the emblem on my 2006 Streetglide? Does the goo removal product leave a mark from the excess rubbing?
Thanks in advance for any help.
Old 04-19-2006, 03:57 PM
aldobrow's Avatar
aldobrow
aldobrow is offline
Stage I
A little wd40 squirted around the emblem with the Dental floss of 6 lb fishing line works great and the wd 40 will remove any remaining stickyness
Old 04-20-2006, 11:12 AM
Hardly Dangerous's Avatar
Hardly Dangerous
Hardly Dangerous is offline
You don't have to rub hard with the Goo Gone so no scratching occurs. One thing to note though, use the fishing line or floss on both sides of the emblem and work toward the center otherwise you risk putting a dent in the paint. I have heard of people working from one side to the other and damaging the paint. Just take your time and work toward the center.
Old 04-20-2006, 11:34 AM
Slider's Avatar
Slider
Slider is offline
ORIGINAL: jsm562
You use the hair dryer to heat up the old emblem...use the fishing line like a knife, put it in behind the edge of the emblem and pull it towards you, along the suface of the tank... if you have the area hot enough it will "slice" it right off.
Quick Reply: removing street glide tank emblems
