Any baggers here with Nitrous Oxide ?
RE: Any baggers here with Nitrous Oxide ?
These guys have tried it all...
http://www.nightrider.com/biketech/nos01.htm
Nitrous from my experience, used properly, really won't be that bad, better if it is a wet kit from what i read.
This is from the nightrider link above..
Q: Will Nitrous affect engine reliability?
A: The key is choosing the correct H.P. for a given application. A kit that uses the correct factory calibration does not usually cause increased wear. As the energy released in the cylinder increases so do the loads on the various components that must handle them. If the load increases exceed the ability of the component to handle them, added wear takes place. NOS kits are designed for use on demand and only at wide open throttle. Nitrous can be extremely advantageous in that it is only used when you want it, not all the time. All NOS kits are designed for maximum power with reliability for a given application.
Engine Mechanical Topics
11-24-2015 06:12 AM
