Oil cooler fan (redux)
Old 04-29-2008, 05:55 PM
iclick's Avatar
iclick
iclick is offline
Default Oil cooler fan (redux)
I just installed two 60mm, 54cfm fans on my HD Premium oil cooler. This isn't the first time I've attempted this, the first being a failure with the fans (80mm, 1.5" deep) installed in front of the cooler causing clearance problems with the front fender. This time I used smaller fans and installed them behind the cooler. These fans barely fit, as you can see in the photo, but it is a nice, snug fit.
A few weeks ago I began talking to Quigley, a member of this forum, who has fabricated a cooler-fan setup that included a temperature probe and adjustable switch. The probe fits in place of the oil-pressure sender or with it when installed with a tee. The switch can be placed anywhere, and it allows temperature regulation. The idea is that when the set temperature is reached the fans activate, then go off as the temperature falls below the set value. I'm more of a manual kinda guy and like making my own decisions about such things, so I obtained two of his fans and rigged the same switch and used the same wiring (never removed) that I used in last year's attempt.
I was concerned about moisture, but he tested the fans by emersing them in water repeatedly, and they still worked even when wet. I plan on keeping them turned off unless weather is dry, but these fans are an experiment. We've both tried to find IP55-rated waterproof fans in this size, but couldn't find any with a decent CFM rating. Another probem is that although there are some being marketed we could not find a source for them in small quantities. Time will tell how these hold up to water and dirt, but being behind the cooler I think they have a better chance to survive. He is selling the two fans alone for $25 including shipping, but if you're interested in the whole kit you'll need to contact him for prices and questions.
Anyway, looking at Photo #1 you'll see how I initially secured the fans to the cooler. On the right I looped them around the side of the cooler, but this could not be done on the left without the wire-tie showing and conflict with the hose nipples. Instead, for the left side I pushed the wire-ties through the opening just outside the fins and used the blunt end of the wire-tie to stop it from the front (see Photo #2). The wire-tie continued through only the back left holes in the fan (top and bottom), and were secured on the rear by the blunt end of a second wire-tie. You can see the setup before I cut the excess. The two fans were wire-tied top and bottom together in the center holes, and these dont touch the cooler at all.
Back to the right side, I initially used the loop idea, but then decided for cosmetic reasons to use the same technique as on the left. After it was all installed I cut the looped configuration and ran the wire-tie through as on the left. It didn't fit in as neatly on the right side, so I only made this change on the top. You might want to do it top and bottom, which is your call. Anyway, you can see that the nub won't seat into the cooler like they did on the left and sticks out a bit.
Photo #3 shows the finished setup, with only that one wire-tie nub showing on the right side. Photo #4 shows the switch on the dash, which isn't nearly as glaring in real life as it is in the photo. The switch (Radio Shack #275-712) illuminates when turned on. I've ordered a second HD accessory switch (71535-96) and will install it later, but this will be only a cosmetic change, as the RS switch works fine. Photo #5 shows the wiring schematic.
I'm hoping this will at least help with hot-weather traffic situations that cause the oil temperature to rise.
Old 04-29-2008, 06:31 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Default RE: Oil cooler fan (redux)
Wow. Nice job. Do you have an oil temp gauge that you can use to check how effective the fans are? Could you repost any info you have on the wiring please?
Old 04-29-2008, 06:46 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: Beemervet
Thanks. Yes, I do have an oil-temp gauge, but I don't expect a good test 'til the weather gets hot. My oil temp rarely exceeds 200° until the air temp is 85° or more. It'll be there sooner rather than later. It must work to some extent, because 100 CFM of air is moving through the cooler with the fans on, which isn't happening in traffic without them. All you have normally when not moving is cooling by convection, which isn't as effective.
Old 04-29-2008, 06:56 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: Beemervet
Forgot to answer your last question. The last photo is a wiring schematic, re-used from my last write-up last May, as was the photo of the dash. The ground wires are connected at the VR, and 12V goes rearward along the frame, then up the frame near the starter, under the seat and tank, and into the fairing insert. The power is obtained from the ACC switch's O/R (orange/red) wire, which is the power wire for this switch and is hot when the ignition is on. It is not affected by the position of the ACC switch and I'm just tapping from its 12V source. The circuit is protected by a 10A in-line fuse, and the switch is grounded under the fairing cap. There are several bolts under there that are good grounds.
Old 04-30-2008, 05:52 PM
quigley's Avatar
quigley
quigley is offline
If anybody is interested they can E-Mail me @ milan_jessica@msn.com
Quigley
Old 04-30-2008, 08:01 PM
Big Nasty's Avatar
Big Nasty
Big Nasty is offline
3rd Gear
First timer cant figure out how to post a Question
Old 05-11-2008, 03:46 PM
iclick's Avatar
iclick
iclick is offline
Default RE: Oil cooler fan - Update
Well, I've made more changes. One of the 60mm fans didn't work well, failing to spin up unless spun by hand first, which wasn't a practical situation. Since they are tucked under the VR, it must be removed or at least raised before the fans can come out. I then came up with the idea of using larger fans, but thinner, so I bought some used Panasonic Panflo 80x80x15mm fans on Ebay. I picked these because they spec out at 70°C max for operating temp, which likely will be exceeded in that environment. Normal fans, if even rated at all, spec at 50°C. These Panflos also have a fluid ("Hydro-wave") bearing, quite unlike a ball or sleeve, and are reputed to be more durable. We'll see about that for the long term.
What's good about this is that the fans slip between the VR and cooler with about 1mm to spare. The bad news is that they stick up a bit above the cooler and I had to make a small shroud with some thin aluminum to keep the leakage around the cooler to a minimum. It's attached with double-stick tape, the kind used for auto trim molding, to the top of the cooler and draped over the fans. I'm thinking 70mm fans might fit better, not poking up above the cooler and maybe not requiring a shroud, but I couldn't find any 70x70x15mm Panflos. These fans seem to put out a fierce amount of air, even though they're rated at only about 35cfm each. You can feel the air flowing from the front of the cooler when they're on.
In rewiring for these fans I added more wire so that if the fans must be removed I'll have about 12" of wire to work with. When installed I fold up the wire and tie it to the frame near the VR.
I also revamped my dash arrangement, buying a second HD Acc switch in place of the gaudy Radio Shack switch I had, and also put in a black push-button switch on the far left, replacing the identical red one I had before. That one activates the garage-door opener and is a Radio Shack momentary switch.
The weather is heating up, almost 90° yesterday, so I'll be testing these fans sooner rather than later. Will report back when I have info on how this works in the real world. I did a 45-mile ride earlier and can report that the fans don't hamper cooling while moving. I thought perhaps they might slow the flow, but if so it doesn't affect oil temps. In this 85° weather they stayed between 185-200° for the whole trip. As for cooling when stationary I know they won't emulate a bike that's moving, but some air over the cooler must help, and will at least slow the ascent of oil temps when in a heavy-traffic situation.
Old 08-16-2008, 11:18 AM
Ram's Avatar
Ram
Ram is offline
Have you thought of thermostatically controled fans?
Old 08-16-2008, 02:54 PM
iclick's Avatar
iclick
iclick is offline
I don't have any interest in that, as I'm a control freak and want to decide for myself when things work. For example, I miss my old carbed RK that allowed me to decide when to deactivate the choke.
Anyway, Quigley (see his note above) was selling some cooler-fan kits that included a thermal switch teed off the oil-pressure sender that could be adjusted to your temperature preference.
Old 08-16-2008, 03:56 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
who is your supplier for the fans I only see 80mm x80mm x25mm no 15mm
Quick Reply: Oil cooler fan (redux)
