Decided to try Royal Purple syn gear lube in my trans..the store I was at had 75W-90 and 75W-140...I know a lot of people run the 90, so that's what I picked up. Any pros/cons to the 140 over the 90?
Mine seemed to shift smoother with 75/140 (Mobile 1) than it does with 75/90. Didn't notice any other difference. I may go back to 75/140, its about $6 more per quart.
A specific oil will have high viscosity when cold and a low viscosity at the engine's operating temperature.
The idea is to cause the multi-grade oil to have the viscosity of the base number when cold and the viscosity of second number when hot. This enables one type of oil to be generally used all year, and when multi-grades were initially developed, they were frequently described as all-season oil.
The viscosity of a multi-grade oil still varies logarithmically with temperature, but the slope representing the change is lessened. This slope representing the change with temperature depends on the nature and amount of the additives to the base oil.
