Hog Tunes, Hog wired, Biketronics
Old 08-27-2010, 12:57 AM
jagonza1's Avatar
jagonza1
jagonza1 is offline
I bike the complete biketronics set up with 6-1/2" speaker but not the amp. I hear it clearly at 90 and still enjoyed it an 110mph on my roadglide and I am running v&h true dual headers with the loud bub7 mufflers.
Old 08-27-2010, 01:46 AM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
Don't forget to consider the J&M 7.25" speakers along with the J&M 250w amp ,,,
Certainly in the running for the BEST SOUND AVAILABLE label ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old 08-27-2010, 01:53 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Why not start a new thead instead of replying to one that is two+ years old?
Carl
Old 08-27-2010, 11:20 AM
dres22's Avatar
dres22
dres22 is offline
I would like to cotrrect something on this thread. 2 OHM vs 4 OHM speakers. 4 OHM speakers will not make your amp work harder and thus add more heat. In fact they are much easier on your amp, however your amp will only put out 1/2 as much power and draw 1/2 as much power from your battery thus less heat. If your amp is rated at 100 watts into 2 OHMs it will only put out 50 watts into 4 OHMs. To get the same volume out of 4 OHM speakers you would need an amp rated at 200 watts into 2 OHMs. (or ratted at 100 watts into 4 OHMs) If the amp is rated for 2 OHMs then you have no problem driving 2 OHM speakers. If your amp is rated for 4 OHM speakers then do not try and drive 2 OHM speakers! Your will eventually fry the amp! Just trying to help.
Old 01-23-2011, 08:33 AM
Orange09Glide's Avatar
Orange09Glide
Orange09Glide is offline
I don't have any experience with the biketronics but do with Hawg Wired. The Hawg Wired is a plug and play system and sounds great at 80+ with loud pipes. I will be attending the V twin Expo in a couple weeks and my main goal is to figure out what system is the best. I will post my finding when I return.
Old 01-23-2011, 10:13 AM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Hawg Wired gets my vote, Great product, great service, loud and clear even with the thunderheader at highway speed.
ridedaddy
Audio Systems
10-18-2013 08:58 AM
vnelson79
12-10-2010 07:27 PM
atrain68
02-21-2010 03:40 PM
Taterdog
04-06-2008 10:02 PM
Marine Trader
02-13-2008 07:10 AM
Quick Reply: Hog Tunes, Hog wired, Biketronics
