compensating sprock comes loose
Went on a poker run last weekend and noticed the bike making a funny noise. Asked my buddies if they could hear it. Their reply was " It's a Harley". Ya,well a guy knows when his bike is making a noise out of the ordinary.
By the time I got home it sounded REAL BAD. Monday afternoon I babied it out to the dealer. Mechanic was standing outside and heard me pull in. Immediately said " sounds like your compensating sprocket is about to flyoff, common Harley problem" Told me what tools I would need and how to fix it if I wanted to do it myself. Of course I did, babied back home with fingers crossed. Made it home and was able toborrowa torque wrench that would go up to 165 ft. lbs. and soon had ittightened back up.Easy fix. I got lucky.
When I had the primary cover off Inoticed the inner primary bolts had bendable tabs tokeep them from coming loose. Not a one of them hadever been bent tohold the bolt. Came from the factory that way. Makes me wonder if the sprocket bolt was ever torqued and locktited. Someone must ofbeen having a bad day. Anyhow, the torque on the compensating bolt should be checked at leastat the 20,000 mi. checkup.
Sharpie
04-18-2014 11:08 AM
20002006, bolt, buell, clutch, compensating, copensating, electra, glide, loose, noise, nut, raodglide, shovelhead, sprocket, torque
