how to attach a guardian bell to the bike
  #61
Old 06-08-2008, 09:52 AM
Scootr's Avatar
Scootr
Scootr is offline
Default RE: how to attach a guardian bell to the bike
Whats up with so many people hanging them up high?&nbsp\\; I always heard its supposed to be at the lowest point on the bike.
&nbsp\\;
There are only 2 rules...
&nbsp\\;
1) Someone else has to buy it for you.
&nbsp\\;
2) Attach bell to the lowest part of the bike.
&nbsp\\;
  #62
Old 06-08-2008, 12:37 PM
russl179's Avatar
russl179
russl179 is offline
I, too, used a zip tie.
  #63
Old 12-30-2011, 12:45 PM
RYGUY73's Avatar
RYGUY73
RYGUY73 is offline
I got a guardian bell for Christmas that came with a metal plate with a hole that I put a bolt through and tightened it with a nut, both of which I painted flat black so they were less noticeable. I put the bell under the headlight, behind the forks.
  #64
Old 12-30-2011, 12:53 PM
ironman2011's Avatar
ironman2011
ironman2011 is offline
Originally Posted by RattleTrap
Mine is on a ring from a keychain
+1 here.
  #65
Old 12-30-2011, 02:17 PM
cp1's Avatar
cp1
cp1 is offline
Have used key chain ring on the old bikes. Now I use zip ties on the floor board mount. 82 yr old father in law wires it to the frame.
  #66
Old 12-30-2011, 02:37 PM
Tinman265's Avatar
Tinman265
Tinman265 is offline
Originally Posted by Oldandslow
I have mine connected with aircraft safety wire to the hinge on the hi-way peg.
As a side note:&nbsp\\; When I had my wreck last year a mechanic at the dealer told me that all the wrecked bikes coming in seemed to have a bell on them, as did mine!
Maybe they don't work? &nbsp\\; Just sayin'
Maybe it could have been a worse wreck......
Your still here!
  #67
Old 12-30-2011, 02:50 PM
mccfeebee's Avatar
mccfeebee
mccfeebee is offline
As was said way earlier in this post it, it must be given and it must be mounted LOW . Low is the only way it will keep those "villians" at bay!!!!
  #68
Old 12-30-2011, 03:06 PM
JimmyDee's Avatar
JimmyDee
JimmyDee is offline
Short piece of SS fishing leader and a compression crimp on floorboard mount.
  #69
Old 12-30-2011, 07:37 PM
ropin4gold's Avatar
ropin4gold
ropin4gold is offline
Black Zip Tie
  #70
Old 12-30-2011, 07:51 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
If you look at the bottom of my rear fender in my sig...its attached by a twist wire key ring, may not be where the legend says it should be but i got the idea from a friend from the forum I rode with couple times.....thats a sweet place to put the gremlin bell isnt it!
Quick Reply: how to attach a guardian bell to the bike
