High altitude ping and knocking
I live in Colorado and my 08 ultra has had allot of pinging and knocking. The dealership has down loaded the most resent program to try and fix the problem, but hasn't done much to help it. They suggested going to a stage 1 on my bike. I had been thinking about doing this even before I started noticing this problem I have. My question is to any one living in a high altitude area that has had this pinging/knocking problem and upgraded to a stage 1. Did it solve the problem?
I tell you it really suxs cruising down the highway trying to enjoy the ride and tunes and all I'm hearing is this constant pinging noise.
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\;
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; Thanks for your help....
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; \\; \\;  \\; \\; \\; \\; Dan
RE: High altitude ping and knocking
Live @ 6000 ft. \\;and I actually just got back from a trip to Denver. \\; I have an 03 RKC w/Stage 1 and have never heard a ping. \\; Looks like from your replies, a stage 1 kit could be your remedy. \\; Good luck and hope it works out for you.
I battled the ping for over a year. \\; Cool temps, no ping. \\; The hotter temps brought on a lot of ping. \\; First I switched to Shell gas (recommended by a friend) That helped about half the time. \\; Then I added a Jagg oil cooler. \\; That took away a lot more ping. \\; I can still get a little ping on ungodly hot days, but only if I use WOT on an uphill grade in high gear. \\; So now I don't do that any more, and I never notice ping at all. \\; Hope this helps.
I live near Colorado Springs - bought my bike (electra glide classic) \\;at pikes peak HD.
I've had NO problems with the altitude.
When I bought the bike I also purchased intake stage 1, Rush slip ons, and download. I had to wait a week or so for the slip ons to come in, so had a chance to put about 500+ miles on it. No problems with pinging. After the install, also no problems with pinging. I had Jim @ Franktown Scooters do the 1000 mile look over, and he thought it might be running too lean. Since it's under warranty (new bike) I had PP HD verify that the mixture is ok (I got this in writing, so if I have problems there will be no problems with warranty coverage).
Here is the strange thing.
Twice since I picked the bike up I've ridden down to California (sea level). \\;Down there it pops and back fires, but not back home in Colorado. I would have thought it would run BETTER at sea level.. This isn't a huge deal, but it is noticible.
So, my guess is that your local HD dealer didn't load the correct download on your bike. Where did you buy it?
