adjusting passing lamps
When you all adjust your passing lamps, how do you hold the lamp and the turn signals straight? I went to adjust mine with the correct tools from snap-on and when I go to tighten up the lamp the lower turn signal piece also turns. I thought I once saw a tool that holds the turn signals straight while you tighten the passing lamp nuts. Any ideas?
RE: adjusting passing lamps
I just did mine so I remember vividly about the directional turning problem.
I'm pretty sure there was a star washer above the nut which causes the problem.
Just get the aim you need with the directional base about 20 - 30 degrees counter clockwise from where you want it to be.
When you bring the nut up to torque , the directional base will follow and be straight when you're done.
Took me a couple tries , but it went smoothly after that.
I just made the socket from an old 9/16" deep 1/4" drive socket and slotted it with a muffler cutter.
To make matters worse , the right adjuster bolt was bent from the factory , making it a real pain to get straight when done.
Good luck and be patient , it's a pain , but well worth the effort.
Mick
Mick
