Harmon Kardon Radio Problems
Old 07-14-2008, 11:32 PM
bk5's Avatar
bk5
bk5 is offline
Stage I
Default Harmon Kardon Radio Problems
Is anyone having problems with the Harmon Kardon Radio Losing Output of Sound? I am on my second radio with the same problem. All is well riding down the highway and the sound just goes away! Flick the speaker switch on the dash and the sound comes back. It might operate properly for another 20 miles or it might go off after just a mile. I am running the Hawg wired amps to power all speakers and do not believe this is the problem. It appears to be an output problem on the HK Radio. Just looking for Help!!
Old 07-15-2008, 09:00 AM
Sharknose's Avatar
Sharknose
Sharknose is offline
Default RE: Harmon Kardon Radio Problems
No, haven't had that particular problem.&nbsp\\; Keep in mind the tried and true Harley wisdom: when something goes wrong, 99 percent of the time it's connected to the last thing you changed.
Old 07-15-2008, 09:44 AM
caspr2's Avatar
caspr2
caspr2 is offline
&nbsp\\;I lost all the volume on mine. They ordered a new radio, still waiting for it to come in.
Old 07-15-2008, 09:47 AM
ALLEN62655's Avatar
ALLEN62655
ALLEN62655 is offline
Stage II
Check to see if the volume level bar is coming on as the radio mutes. My 08 is in the shop now because the radio volume level bar shows and the radio mutes all by its self. I will answer back today after I find out what the problem is.
Old 07-15-2008, 09:58 AM
rick867's Avatar
rick867
rick867 is offline
my 06 ultra did it,radio has abad audio amp needs to be replaced
Old 07-15-2008, 10:21 AM
dale51racing's Avatar
dale51racing
dale51racing is offline
If you flip the speaker switch on the dash and it comes back on it sounds like you might have a bad connection in the switch. Try running it in the middle position and see if that helps.
Old 07-17-2008, 01:34 PM
ALLEN62655's Avatar
ALLEN62655
Stage II
Mine turned out to be a bare wire under the fairing.
Old 07-17-2008, 03:34 PM
stro1965's Avatar
stro1965
stro1965 is offline
I lost sound on mine twice last summer.&nbsp\\; Had to shut the bike off and mess with fuses to get it back.&nbsp\\; Over the winter I pulled the front end apart, to include inner fairing, and reassembled.&nbsp\\; No problems yet this year.&nbsp\\; Makes me think if it might have just been a bad connection somewhere.
&nbsp\\;
Old 07-17-2008, 04:03 PM
johntheone's Avatar
johntheone
johntheone is offline
Check the basics, most audio equipment will suffer connection problems. May also be an indication of a dry joint in the radio or amp, start with the basics before ordering a replacement.
Old 07-17-2008, 04:08 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
i lost sound on 1 speaker once it was the connection spade on the speaker broke off
&nbsp\\;
replaced the speakers with jbl,s sounds great now-ride safe
Quick Reply: Harmon Kardon Radio Problems
