Vance & hines exhaust question
Old 08-14-2008, 11:53 AM
joechief's Avatar
joechief
joechief is offline
Default Vance & hines exhaust question
I have an '06 Road King Custom that I am either going to put on a Vance & Hines #16745 Monster Oval Slip-On mufflers or part #16727 Oval Slip-On muffers. The question is: do I really need to buy the V & A reprogrammer for $300.00 or can I safely just install the mufflers? I just like the looks and sound and am not so concerned about added performance. My bike goes fast enough for me.
Thanks,
Joechief
Old 08-14-2008, 12:06 PM
leohd's Avatar
leohd
leohd is offline
If you still have the stock air filter you should be alright without it, just check your plugs and see how it runs
Old 08-14-2008, 12:18 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Most slip-ons will work without and problems..
Old 08-14-2008, 01:30 PM
Peppa1's Avatar
Peppa1
Peppa1 is offline
If ALL you do is add the slip ons you should be just fine. If & when you add a high flow A/C the you'll need to look at a Fuel Pak or similar fuel mgt. system.
Old 08-14-2008, 01:52 PM
joechief's Avatar
joechief
joechief is offline
Thanks for the replies everyone, I'll give the sip-ons a try and see how it goes.
Joechief
Old 08-14-2008, 02:21 PM
cybdet's Avatar
cybdet
cybdet is offline
I have the slip-on V&H ovals and I can tell you from experience that my bike seems to be running very lean. I will be buying a PCIII at the end of the season along with headers or I will be selling the V&H ovals and buy a 2-1.
JMHO & Experience.
--CYB
Old 08-14-2008, 02:34 PM
YtseJam's Avatar
YtseJam
YtseJam is offline
You will be able to run it without, but as was said, you will probably run lean.
Old 12-08-2008, 12:12 PM
gvera's Avatar
gvera
gvera is offline
I'm in the process of buying the V&H Ovals 16727 for my stock 03' Ultra Classic - I've done an extensive amount of research and concluded I should add the V&H Fuel Pak (V&H Fuel Pak works good with V&H mufflers) and while I'm at it a K&N RK3909 high performance A/C - my objectives for the upgrade was to increase/improve the sound and additional "get up and go" - as soon as I get and install everything and the weather improves here in the Midwest (which should be in the spring), I'll post a thread.
Old 12-08-2008, 02:05 PM
bartb1200's Avatar
bartb1200
bartb1200 is offline
I have the monster oval on my street glide you will love them
Old 12-08-2008, 03:05 PM
bdp's Avatar
bdp
bdp is offline
The monster ovals are perfect for me. Great sound!
Quick Reply: Vance & hines exhaust question
