Leaking oil from clutch cable adjustment
Old 08-25-2008, 07:26 AM
Fallston HD's Avatar
Fallston HD
Fallston HD is offline
Stage III
Default Leaking oil from clutch cable adjustment
I have a 2001 Ultra Classic that is leaking oil from the clutch cable adjustment. Is this a sealed fitting that needs to be replaced or is there other problems that I should address? Or will a clutch cable replacement take care of this?
Old 08-25-2008, 07:37 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
If it is leaking at the end of the cable at the transmission cover,try to tighten the hex nut on the end of the cable.There is also an o-ring there for sealing.
Old 08-25-2008, 07:43 AM
frankharley07's Avatar
frankharley07
frankharley07 is offline
My 07 Ultra Classic was leaking and I had it replaced. They said that after a while this happens.. I guess the O ring dries up.
Old 08-25-2008, 08:24 AM
racklefratz's Avatar
racklefratz
racklefratz is offline
Wow - an '07? That's not much of a "while". Seems like it shouldn't be a problem so soon.
Old 08-25-2008, 08:57 AM
shamboogiebanger's Avatar
shamboogiebanger
shamboogiebanger is offline
WTF? my 07 is doing the same thing! doesnt leak much but come on, its an 07! it should not be all dried up already. this makes me wonder how many people this is happining to.
Old 08-25-2008, 09:09 AM
johnnyspeed's Avatar
johnnyspeed
johnnyspeed is offline
mine leaks too
Old 08-26-2008, 05:44 AM
Fallston HD
Stage III
Thanks
Old 08-26-2008, 05:47 AM
Fallston HD
Stage III
It's leaking at the clutch cable adjustment, the strange thing id this fitting is above the trans.
Old 08-26-2008, 06:08 AM
Old Bones's Avatar
Old Bones
Old Bones is offline
Mine leaks on a 08, not enough to drip, just enough to collect dirt.
Old 08-26-2008, 06:37 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
+1 on my '07. No big deal. Hey, it's a Harley. What do you expect?
Quick Reply: Leaking oil from clutch cable adjustment
