It should blink when you first start up, but go out. If it come on solid you have a problem with the ABS.
Thats what the dealer told me. Hope this is correct.
I have a 08 strret glide and had to take it back because the ABS stayed on. They replaced the modua. I see you have a set of rineharts on your bike. I'm thinking of doing the same are they true duals and what type of air cleaner and tuner (fuel pak, power comander) did you install and are happy with them. let me know. thanks, joe
The ABS light blinks until you put it in gear - If you really bottomed out rather hard, you may have displaced the sensor that tells the ABS that your in gear - does your neutral light work OK?
rinehart td's , and sert and se ac , i couldnt be happier with them. i gotta see if putting it in gear shuts it off, i just dont remember it staying on more than a few seconds after i start it. nuetral light works fine
