Sony radio install on FLHT
Old 03-22-2006, 03:14 PM
capt42a's Avatar
capt42a
capt42a is offline
Default Sony radio install on FLHT
Hello everyone,
I have a Sony radio, Biketronics Retro Radio kit (on the way), Tune Trapper antenna, and Hog Tune speakers that I'm going to install on my 2006 FLHT/I as soon as the Retro Radio kit arrives. Do I need anything else to complete the installation ?
Thanks for the replys.
capt42a
Old 03-22-2006, 04:41 PM
V2 Bagger's Avatar
V2 Bagger
V2 Bagger is offline
Default RE: Sony radio install on FLHT
Nope, its a pretty easy install. Plug and play. Having a long Ball end type allen wrench helps alot with bolting the radio in. Also cover your passing lamps up with a couple of rags before you pull the bat wing off.
What model sony did you get??
V2
Old 03-22-2006, 05:33 PM
Bushy's Avatar
Bushy
Bushy is offline
and cover that front fender!!!!!
I installed that radio and hook up on my standard. only problem I had at first was the wires to the speakers, they are orange and white not red and white. if this gives you a idea of the simple design Mike set up then there you go. works great and l,ooks good!!
good luck
Bushy
Old 03-22-2006, 07:08 PM
capt42a's Avatar
capt42a
capt42a is offline
V2 Bagger, I bought the Sony CDX-F50M, thanks for the reply, also thanks Bushy.
capt42a
Jimmy Carter
Audio Systems
05-17-2019 04:59 PM
madcardisease
05-30-2012 06:23 PM
so165
09-28-2008 01:10 PM
capt42a
04-11-2006 12:21 AM
capt42a
03-01-2006 11:35 PM
Quick Reply: Sony radio install on FLHT
