Rinehart Baffle Removal
Hello all; I just received a pair of Rinehart Quiet baffles. The problem is that I can't get the old baffles out. I took the end caps off. Even started the bike up and let it run for 5 minutes. Still the baffles won't pull out. Is there a trick? I can't find the Rinehart web site to contact them. The new baffles look to just push in. Thanks for any and all help
The baffles will be a real pain in the a$$ to remove due to the carbon build up and the rust that develops.
Does the baffle on the Rineharts extend past the body of the muffler, or is it short of the body?
If it's short of the body, you could try slamming it down on a thick phone book or piece of pine..........that would knock the baffle loose. And you could do this same trick to install the new quiet baffle.
If the baffle is longer then the body, it's going to take a lot of elbow grease..........and wd-40. Spray wd-40 on both ends of the baffle and let it soak in. Then grab ahold of the baffle and start to wiggle and pull and twist all at the same time.
Steve
Steve
Baffle removal
When I had my Reinharts I ordered a set of the performance baffles from (The loud ones). I tried several times to remove the baffles and had no luck. I even drilled a cross hole in the end of the baffle and attached a slide hammer to the pin. No Luck!. I had the bike walking across the floor with each hit. NO LUCK!!. I wound up sending the baffles back. When I spoke to Bub/Reinhart the tech told me to spray a little windex in there from the head pipe side. Yeah Right. I was not able to knock them out from the head pipe side because they fit up against a shoulder so the inside was smooth.
I sold the Reinharts to a guy that loved the sound as is. God Bless him......
Rinehart Baffle Removal Revisited
Hello all; Well, I tried everything. Broomstick, taking the mufflers off and spraying Windex too loosen them up, then WD-40. They simply won't budge. Also, you have to be carefull not to distort the end of the baffle, or the end cap won't go on. So.... you can't put on the vice grips and start twisting. (The baffles are flush with the end of the muffler).
So I decided to take the Rinehart mufflers back off and reinstall my slightly cored out stock mufflers. Wrong!!!! The Rinehart head pipes are larger than the stock pipes, so the mufflers went into the Rinehart pipes and not over them. That won't work as there is no way to clamp the mufflers tight, and it looks bad as the heat shields don't go to the end of the Rinehart pipes.
So if anyone has quieter mufflers to fit the Rinehart pipes, I may be persuaded to trade. I'll even include the Quiet Baffles that I waisted $119.00 on.
Or better yet, maybe someone knows how to get the performance baffles out.
Any ideas?
Any ideas?
