Removing 08 roadking fuel tank
first you have to rent a 90 lb jack hammer, Smith 90 compressor, and a 6' pry bar.....then have at it.
Actually....very easy on the 08's....no crossover line to mess with. Just drain the tank, and remove the line going to the petcock by pulling up or down on the retainer ring and then pull the line out. It has a auto shut off valve in the petcock, so the fuel will not come pouring out when you remove the line. Then just lift up and to the rear.
If your too nervous about it....just buy a 08 service manual....it tells you step by step how to do it.
