Front motor mount
Old 11-26-2008, 08:23 AM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Default Front motor mount
I picked one up yesterday from the dealer, most updated part number. So, which side goes up? One side is pretty much flat, the other is beveled. The old one is so destroyed that I cant tell which way it was. BTW, it is on a 2006 SE ultra.
Old 11-26-2008, 09:46 AM
robzuc97's Avatar
robzuc97
robzuc97 is offline
I really hope your using a service manual but it's your life (literally)! Hope you didn't move the jam nuts on the stabilizer link. The "mostly flat side" goes down and the "bell shape" (beveled one?) goes up. Bolts should just drop right in with engine flange evenly positioned on the mount. Torque of all three engine mount bolts is 15-20 ft-lbs and the engine-to-flange mount (two top ones) is 33-38 ft-lbs.
Old 11-26-2008, 10:00 AM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
Just a tip: after going through a number of motor mounts on my SG I finally realized that the most important aspect toward longevity is the proper torque specification.
Don't ask how I know!
Old 11-26-2008, 12:37 PM
Point Man's Avatar
Point Man
Point Man is offline
You should have a Repair Manual for your bike; makes life easier.
I just did a front motor mount and went with the Velva-Ride brand (got it through J&P). It's urethane and not rubber and will outlast the Harley one. Comes with all the instructions, too. Many threads on motor mounts here so use the search option.
Since your '06 mount crapped out in 2 years, I'd consider the Velva Ride...many happy customers. It's about $110.00 but worth it in the long run, considering what you paid for your ride! I'd consider returning the H-D mount and ordering the VR.
Old 11-26-2008, 12:57 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
i read here that buell has a replacement motor mount that works better than harleys
or kury's. buell part # lo501.2 the harley dealers stock them about $55.00 or
zannoti for $36.00
ride safe
Old 11-26-2008, 01:23 PM
carpetride's Avatar
carpetride
carpetride is offline
buell mount is not anything special, just a different stock # .... go with the velva ride
fshaw
EVO
30
09-21-2018 08:14 PM
Stanger
04-11-2009 10:31 AM
Streetrunner
04-10-2009 09:10 PM
6speed
01-19-2009 07:39 PM
dhutchison
07-17-2006 12:09 AM
Quick Reply: Front motor mount
