SE Big Bore Kits 88ci vs 96ci
Old 11-30-2008, 08:34 PM
Lookin4somehelp's Avatar
Lookin4somehelp
Lookin4somehelp is offline
Stage IV
Default SE Big Bore Kits 88ci vs 96ci
Hello, I'm fairly new to the site (read a lot, don't post so much....) anyways, I need some help. Is there a difference in the heads and pistons in the SE big bore kits for the 88ci and 96ci motors? I realize that the air cleaners are different (efi/carb etc.), but are the jugs and pistons the same? Thanks
Old 12-01-2008, 08:53 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
I think the question should be 88/95
not 88/96
The twin cam 96 has a stroked crank so it can go to 103 without installing a stroked crank.
Going to 95 ci from a 88 ci seems to be the norm.
From what I have read head work should be considered to get the best results.
I suggest sticking with big bore parts that have been know to work well together. Big bore kits/parts need to compliment each other(work together) to produce a good running engine.
Old 12-01-2008, 10:11 AM
rochkes's Avatar
rochkes
rochkes is offline
I am not sure what your question is, but I believe you are asking if the same big bore kit is needed for an 88ci motor as a 96ci motor. The answer is no.
Dennis
Old 12-01-2008, 12:28 PM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
The short answer to your question is yes, there is a difference. The two are completely different motors even though they're both Twin Cams. You cannot use the SE 96" parts on an 88" motor.
EL in NH
Engine Mechanical Topics
41
12-09-2022 09:54 AM
Goose_NC
General Topics/Tech Tips
20
12-29-2016 12:27 PM
CaptainHook
02-26-2016 06:59 PM
James Butler
EVO
08-01-2010 12:21 AM
cruiser08
09-14-2008 10:54 PM
Quick Reply: SE Big Bore Kits 88ci vs 96ci
