flame throwers
flame throwers
Anyone ever play around with the flame throwers you can install on vehicle exhaust pipes? Basically, all they do is ignite unburnt fuel with a spark plug in your exhaust pipe....
http://eatmyflames.com/
I've seen some products online that actually inject a bit of fuel into the exhaust for an added effect.
These things are highly illegal by the way.
Anyway, it seem flames are a very common theme on a lot of bikes, maybe some real flames would add to the effect.
I remember that. I also remember someone saying that is not the smart thing to do because it allows raw fuel to go through the motor and wash the cylinder walls. I wonder if these kits are made the same way now days.
How about a 50 cal simulator (Browning 50 Cal machine gun).
easy to make with some pipe, a coil and battery and some kind of timer to fire the device. Cadence is vital to getting the correct feeling of authenticity. The M2 Browning has a distinctive rate of fire.
If you had a 2-into-1 exhaust, and a ghost pipe, you could set the ghost pipe up with this rig to simulate machine gun fire.
kewl.
http://www.intlrepo-depo.com/Simulat...tersManual.pdf
kewl.
