Anyone using Dakota Digital Gauges?
#31
#33
#34
#36
Cons, so over priced it makes me want to puke!!!
#38
#39
I just installed mine last week. The Dakota Digital gauges has a user method of setting the odometer to the correct milage from your original gauge, but you have to do it within the first 100 miles
odoMK Odometer preset
The odometer can be preset by the customer within the first 100 miles. Once the odometer has more than 100 miles the
menu option will no longer be displayed. Make sure you have correctly selected the units to be either MPH or km/h first. The
odometer will be set in the selected units. Once you have preset the miles you cannot change it again. WARNING!!: This only
allows setting odometer to the nearest mile. Do not use tenths! For example a mileage of 65432.1 should be set to
“065432” using this method. If the tenths digit is used, the odometer will read 10 times too high.
· Press and release the switch until “-odoMK” is displayed, then press and hold the switch until “ - ” is displayed.
· The current miles will be displayed with the left most digit flashing.
· Press and release the switch to increment the digit. Press and hold the switch to move to the next digit to the right.
· Continue until the right most digit has been set. Press and hold the switch and the speed display will show “No”.
· Press and hold the switch while “no” is displayed to go back and continue changing the odometer display. Turn the key off to
cancel any changes.
· Press and release the switch to change to speed display to “yes”. Press and hold the switch while “yes” is displayed to save the
current odometer reading.
cancel any changes.
#40
