I bought the classic because it was like $40 cheaper.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________ Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it. - Ronald Reagan .... We (the United States) tax everything that moves and doesn't move..... - Hillary Clinton
I am powering the gloves directly into the battery.
If you want the gloves, you better get them soon. Gerbing has stopped production of them and are now making glove liners. Have the gloves myself and did check out the liners the other day and prefer the gloves. Also, they have quit making the socks and are now making heated inserts. Have not seeen these yet.
I really don't need a jacket or vest. That jump of mine lacks nothing. That's why I'm wondering about the wiring. There'll be no jacket to plug them into. I just hate to go with Hippo Hands or the like.
- adjustable thermostat not standard-on/off only
Yup, definitley.
- Do not use the Battery tender hookup. check the fuse amperage in the hookup and you'll understand why.......Use the Gerbing's battery pigtail, they have a converter that allows you to connect to the Battery Tender. ??? - So I don't go to the battery without G's pigtail...? Cool. The SAE2 receiver would be next to the tender SAE2, perfect conveinence. A thought... wonder if I can use the same wire I use for the tender to plug the gloves into. One wire instead of two; obviously both would never be used at the same time. Change out the existing wire to G's pigtail...? How's that sound? - I bought the classic because it was like $40 cheaper.
I feel strongly both ways, G3 & Classic. I think it wise to talk to Gerbing first, then find a local dealer. Hopefully the closest one is about 100m away calling for a good ride !
I really don't need a jacket or vest. That jump of mine lacks nothing. That's why I'm wondering about the wiring. There'll be no jacket to plug them into. I just hate to go with Hippo Hands or the like. WIthout the jacket or vest, you may have a larger issue with the gloves. You will still have to run the cord up thru your jacket and down your sleeves. Length MIGHT be a problem depending oin your height.
Yup, definitley.
??? - So I don't go to the battery without G's pigtail...? Cool. The SAE2 receiver would be next to the tender SAE2, perfect conveinence. A thought... wonder if I can use the same wire I use for the tender to plug the gloves into. One wire instead of two; obviously both would never be used at the same time. Change out the existing wire to G's pigtail...? How's that sound? Thats what you need to do. Use Gerbings pigtail and they have an adaptor that allows you to use the battery tender on it. Adaptor is only 6 inches long.
Tkx all!!
I use the Vest myself, and I ride in temps down to 25 F. Add the gloves, and I stay toasty all day long.
__________________
Lowering the income of our middleclass will not help us to get our economy moving. The more people unable to afford things, the worse our economy will become.
I looked at both the HD gloves and the Gerbing G3s and bought the Gerbings...mainly due to the G3 being all-leather and the HD having quite a bit of textile in the construction. The G3 just seemed better made.
One thing to note: neither comes with a thermostat, but the HD gloves to come with an on/off switch that the Gerbings do not. If you like that switch in lieu of the thermostat, it's only ten bucks.
I got the G-3's a little less cumbersome than the older model. I didn't get the thermostat, don't need it. Don't wear a vest, if it's that cold I don't need to be out there. I have the HD model, hands stay dry and warm no matter what. Ride into the thirties but no less.
__________________
'09 Ultra Classic Electra Glide
Flame Blue Pearl/Pewter Pearl
PGR #163854
Seems gloves are the only thing I'll need. Thought I'd hook 'em up to the tender's SAE2, a direct line to the battery.
You won't like the gloves if powered without a switch. I had my Gerbing Classic gloves connected to the ACC switch, which worked well but forced me to do too much toggling while riding, as these gloves do get uncomfortably warm in time. I bought the HD single controller because it is much cheaper than the Gerbing if purchased from Chicago HD ($48) and includes the belt-clip pouch that is optional ($10) with the Gerbing. They are identical except for the HD logo on the pouch and controller.
Quote:
- the wire is a pigtail. Wire to each glove 7 a main to the tender's SAE2. Hopefully the wires are long enough to accomodate long arms and down to the SAE2.
I would check the fuse to the Battery Tender connection, as the gloves pull about 3A. I doubt if this would be a problem using gloves only, and I assume you would never use the gloves and something else together on that circuit, but I would check the fuse rating for the BT to make sure it is up to the task.
Quote:
- an adjustable termostat is standard
No, it's optional. For gloves only you'll need the single controller, but if you ever decide to add more items (i.e. liner, pants, etc.) you may need the dual controller. With it you can control the gloves and liner separately. I have the Gerbing Classic gloves and have ordered the HD jacket liner ($165 from Chicago with their now-expired Holiday25 25% one-item discount), and will try my single controller with "Y" adapter for a while since I already have it. I'll get the dual-controller only if necessary.
I can't speak for the HD gloves, but they're made by Gerbing who will provide a lifetime warranty on the electrical components just like their Gerbing-branded items. I have the Gerbing Classic gloves which work well but are a bit bulky. The G3 might be a better choice even though they cost more, although I can't complain about the gloves I have.
__________________
2007 Street Ultra
Stage 1½: Fuel Moto Power Package, SE255 cams.
gerbing makes the gloves for H-D, the one year warranty is for craftsmanship lifetime on heating elements. i have friends who have both and was told gerbing get warmer then the H-D.
