Zumo Wiring
Old 01-06-2009, 06:58 PM
saw*me's Avatar
saw*me
saw*me is offline
Default Zumo Wiring
Where did you hook up the wiring for the Zumo ? Going to mount it on the handlebar. I have an 04 RG.
Thanks Tom
Old 01-06-2009, 07:14 PM
NoKenDo's Avatar
NoKenDo
NoKenDo is offline
Someone with a R/G will chime in soon.
On my Batwing I spliced into the cig lighter
for power. Then I ran the audio cord through the left
side of the Batwing and out the right side to the Aux
input for the radio.
Old 01-06-2009, 07:29 PM
dawg's Avatar
dawg
dawg is offline
Received 2,938 Likes on 1,701 Posts
I used the HDI unused connector behind the headlight and then ziptied the extra wiring the fairing bracket. Then I wired a two pole flat connector in line to take it off if I want
Old 01-06-2009, 07:31 PM
AtkRWC's Avatar
AtkRWC
AtkRWC is offline
Wired it thru the ACC switch which is actually in the Batt Box area. Ran the wire under the Tank.
Old 01-06-2009, 07:36 PM
NoKenDo's Avatar
NoKenDo
NoKenDo is offline
I had already used that one for my
Engine guard mounted fog lights.
Old 01-06-2009, 08:06 PM
soos's Avatar
soos
soos is offline
Why would you need to splice the line in order to take it off? Isn't it wired into the cradle leaving the Zume free for removal? Or are you talking removing the entire mount?
Old 01-06-2009, 08:09 PM
dawg's Avatar
dawg
dawg is offline
entire mount
Old 01-06-2009, 08:28 PM
saw*me's Avatar
saw*me
saw*me is offline
Thanks guy,s
The Acc is not used at present so that may be my option.
Tom
Old 01-06-2009, 08:41 PM
jcbpa's Avatar
jcbpa
jcbpa is offline
ATKRWC, did mine the same way... not sure I understand the question. But I got here late, and with Dawg and Soos on it, you've got some good advice coming your way.
Old 01-07-2009, 05:57 AM
Pastor John's Avatar
Pastor John
Pastor John is offline
I came down the handlebar to the tank console, then down to the accessory plug off the battery. Used the HD splitter so I still have an accessory outlet when I need it.
Quick Reply: Zumo Wiring
