Progressive Rear Suspension Link
It was only the matter of time until progressive got thier hands in the cookie jar. Anyone try thier new rear suspension link that has no clearance issues? The price ain't bad either MSRP of $199.00. I have pushed my SG pretty hard and haven't experienced any issues, however, for this price I just might give it a go.
Pictures of Installed Progressive Link
There are no ground clearance issues. Two pictures attached.
Installation required removal of right saddlebag, right passenger footboard and loosening up the D&D Fat Cats in order to get the Prog Link installation done. The actual bolting-on of the Prog Link takes less than 20 minutes, followed by reinstallation of all the other stuff. Two hours total.
I removed the muffler from the endpipe and removed the 4 nuts from both head pipes. There's also a bracket on the underside of the Fatcats that bolts to the frame and has to be removed too. {There is no need to remove the O2 sensor plugs from the head pipes.} Taking all that stuff off lets you shift the head pipes around so you can get access to the frame to remove the existing swingarm mount and replace with the new Touring Link frame mount. There's no need to completely remove the head pipes, at least not on an 07 Street Glide.
