Batwing Fairing Vibration Repair
Has anyone used this kit from Savior to repair Batwing Fairing Vibration?
http://www.savior250psi.ca/QuickRepair_about.html
I looks like it is just a bushing and a bracket. From what I have read it seems it is a fix for the vibration of some sort of onboard compressor that is used to air tires, or shocks. I am not sure.
I have problems with my batwing squeeking when I come to a stop at a light, and it gets on my nerves, but, vibration has never really been that much of a problem for me.
If you don't want to remove the outer fairing, you can hold the handlebar grip with one hand and push the outer edge inner fairing with the other hand. There should be very little movement of the fairing. If the fairing bracket is broken, the fairing will move quite a bit. Repeat to check the other side.
You can fix broken vertical brackets without spending any or much money. With limited expertise and tools for working with metal I was able to do it, so most everyone should have little trouble. I did a write-up here after discovering that I had both the left vertical and right horizontal brackets broken. I fixed the broken left and strengthened the right vertical in such a way that I think will hold for the long-term. Time will tell, but if the fix breaks you can always fix it again with something stronger.
The design of both types is weak, IMO, and I couldn't figure out a way to improve the wimpy horizontal brackets made by HD. Howerver, someone who posts on Harley Tech Talk's Twincam Swap Meet forum makes SS versions of the horizontal brackets for $55 including shipping. The cheap HD brackets are $8, IIRC, but they will just keep breaking every year or two. I may go for these to prevent breakage when replacing is inconvenient, like on a trip. BTW you must register with HTT to gain access to the Swap Meet forums.
