Stage 1 or 103" Upgrade
Out riding today and stopped by my dealer. Discussed Stage 1 upgrade, but he said the best bang for the buck was to go ahead and do the 103" upgrade. Yes, more money, as he indicated the 103" would run about $1600 - $1700. He never quoted the Stage 1, so I'm not sure what the typical Stage 1 upgrade costs.
Question to the all knowing.... Do you save up for the 103", or do the Stage 1 and then work toward the 103" later...... Are the gains of the 103" worth the price?
I actually picked mine up off the showroom floor with the Stage 1 103" (with stock cams). I am rather happy with the numbers from it. The sheet below was in the same configuration I picked it up in. Since then I have added PCV with Autotune and Jackpot Mufflers. I am playing with the Autotune for a few weeks and then I'll go get another few runs on the dyno to see what the change in numbers were.
It suits me just fine....pulls like a Supercharged John Deer.
I did the stage 1 for about 850.00 plus dyno(barterd that)..Its all bolt on so you can do it then bring it in for the dyno witch a good dyno runs 250-350 depending who you have do it.......Your not out much if you up grade later.....If ya do geardrive cams then thats the time to do a stage two......I think labor for a stage two is around 8-9 hours including dyno time.....
doing a 1 then a 2 you basicaly will end up paying for 2 dyno tunes...being how you have no labor but your own on a stage 1....
Just wondering which may be the best for the money you spend....
Tks for the input!
