How many hours to mount the Custom Auxiliary Lighting Bracket Kit
Hi
I see many has the auxiliary lightning on their street glides.
How many hours will it take to mount it?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Hi
I want to say it took me 4 hours, but most of that was spent running around to friend's houses and auto parts stores trying to find someone with a crimping tool for the terminal connections. That and fishing the wires through the new brackets were the only difficult parts of the install. I ended up using small precision needlenose pliers to approximate the factory crimp, then I used electrical solder on the "crimp" to ensure electrical continuity.
I'm going to suggest you approach your dealer service dept and ask what they charge to supply and install the lighting. Perhaps they will give you a break on patrs cost and install.
Your other option is to check local indies to see if they have proper crimp tools to do it right.
I've ran into the same problem when attempting to crimp most HD electrical pins....the danged crimp tools can cost up to 300 bucks!
It took me about 2.5 hours for install. I found a crimping tool online that worked great. Google BCT-1 crimping tool. Got mine from B@C Specialty Products Inc. out of Newton, Kansas. It has 5 different crimping sizes. And also handles from 16 to 30 AWG wire. Good Luck
