Best oil filter for 09
02-15-2009, 07:03 PM
Time to change the oil. Is HD the only filter for these bikes?
02-15-2009, 07:09 PM
Nope not the only one, but it is a good choice. 5 micron
02-15-2009, 07:11 PM
using the amsoil chrome filters.
02-15-2009, 07:27 PM
I like the K&N with the welded nut on the bottom. Makes removal easy. HD one was a chore to remove.
02-15-2009, 07:30 PM
I too use the K&N with the nut welded on it. Simple, simple removal and install. I believe the part number is KN-171C
02-15-2009, 07:36 PM
I like the WIX. I believe it's 5 micron.
02-15-2009, 07:45 PM
Not only the micron rating, but you need to be concerned with the bypass pressure ratings. Here's a list of cross referenced filters for HD
These Oil Filters
have 3/4" x 16tpi threads,
8 psi by-pass valve,
anti-drain back valve.
Available filters include
Purolator PL10241 / PL25230
Mobil1 M1-102
Bosch 3330
AMSOil SMF 133/134/135
Baldwin B1413
Fram PH6022, PH6065A
Hastings LF576
NAPA 1348
Purolator ML16822
WIX 51348
02-16-2009, 11:55 AM
No that some of the aftermarkets aren't OK but why not get the one that is made & recommended for your bike ? The GOOD aftermarkets aren't any cheaper !!!
02-16-2009, 12:57 PM
I.am thinking...Amsoil chrome or black is a 3 micron {which is finer} + alot cheaper in Canada.
02-16-2009, 03:51 PM
Do any of those "after-market filters" listed have a NUT welded to the bottom like the K&N?
