FLHX toupack problem
Old 03-10-2009, 05:39 AM
1mcrider's Avatar
1mcrider
1mcrider is offline
6th Gear
Question FLHX toupack problem
Has anyone else ran into this problem and if so what is the fix?? I have just installed a king tourpack on my streetglide with the quick disconnect hardware. My problem is with the backrest on the tourpack. It is the backrest that matches the seat on the streetglide. When I mount the backrest to the tourpack it does not fit like it should to the tourpack lid. It leaves about a 1 inch gap between the backrest pad and the tourpack lid. I talked to a hd parts mgr. and he happened to have the same thing that they were working on for a customer. It had the same problem. I have tried every thing including drilling the brackets on the backrest and it has helped some but I stll have a little gap. any suggestions?????????
Old 03-10-2009, 05:48 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
From what I remember it was the same way on mine. I lived with it. Assumed that was the way it was supposed to be.
Old 03-10-2009, 05:59 AM
riteway's Avatar
riteway
riteway is offline
I think its suppose to be like that,Mine is same and i THINK its so it doesn't rub and also EZ cleaning???.... Good Luck..R.W.
Old 03-10-2009, 12:13 PM
iunlocku's Avatar
iunlocku
iunlocku is offline
Default Different Problem with 2006 FHLX Tour Pak
I don't know if I have the problem with the seat not going back flush against the tour pack. If it does not sit flush its uniform to the point I don't notice it.
The problem I'm having is after installing the detachable hardware and pak every thing works fine can take it off and on with easy. After I installed the detachable lock now I have to loosen the bolt that hold the mount were the lock is to remove or install the Pak. It appears that he lock is to thick for the mounting post. Any thoughts would be helpful.
Thank you.
Old 03-10-2009, 12:25 PM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
Mine has the same gap, I just ignored it. Thought they are all that way.
Old 03-10-2009, 02:33 PM
falbound5's Avatar
falbound5
falbound5 is offline
I have the same gap, looks like the way it was engineered. No problems with it
Old 03-10-2009, 02:41 PM
QSRYDR's Avatar
QSRYDR
QSRYDR is offline
Same gap on my 09 FLHX.
Service manager told me it's because the backrest is a one piece style. The factory backrests are two piece style and the top part fits closer to the tour-pak lid.
Old 03-10-2009, 03:41 PM
Lowridin packer's Avatar
Lowridin packer
Lowridin packer is offline
I have a comfort stitch backrest on my 09 king tour pak and there is no gap. kind of strange they would leave a gap.
Old 03-10-2009, 04:14 PM
jeg1's Avatar
jeg1
jeg1 is offline
Thank you.
I installed a King Tour Pack this weekend and fought the detachable lock also,ended up not using it. I put a Smooth sundowner seet on mine cause the passanger pillion was a little wider [no she doesn't have a big ***]so i got the smooth passanger backrest and no gap.
Old 03-10-2009, 06:09 PM
ovalracer's Avatar
ovalracer
ovalracer is offline
6th Gear
Just installed King Tour Pak on 08' FLHX.Had the gap but its uniform so figured it was supposed to be there. I had no problems with the detachable lock. If it's installed on the left inside of the Tour Pak rack which I assume it is I recalled having to change the spring washer on the rack side of the pivot shaft and replace it with the flat washer supplied. If you didn't do that then it would force the latch too far inboard on the docking point.If you didn't change the washer that,s what I would check first.
Quick Reply: FLHX toupack problem
