Oil Cooler install question
Anyone have the hd oil cooler and the hd temp gauge installed in the location indicated by the directions (in an adapter behind the old filter).
The dealer installed the oil temp gauge when I got the bike I was just wondering how that works with the hd oil cooler.
Pics would be great Thanks.
I do not have mine that way but it will work fine.
The main difference is it will not read the temp from the pan...but from the output of the cooler. This will not be an accurate indication of oil temps until the oil cooler bypass opens at 185 degrees. You should see very little movement on the oil temp gauge until the bypass opens and then it should read accurately.
Temps may be a bit lower than what others report as normal temps in the oil pan...but close enough to identify a problem if it were to arrise.
If you are doing the initial oil cooler install...don't put the gauge back the way the directions tell you to. Do it the way it is detailed in this thread. here
You'll have a better indication with it in the oil pan and it won't be affected by the operation...or non-operation....of the thermostat. JMHO.
Since you will already be working in that area...it's a great time to fix it.
One thing you do need to know...
The oil filter adapter for the oil cooler requires a 7/16 allen socket to torque it down. 7/16 is larger than you will probably ever find because most kits end at 3/8. Do what everyone else has done...and what I had to do...
Get a 1 1/2 to 2 inch long bolt with a 7/16 hex head and a few nuts. Put the nuts on the bolt and use wrenches to jam the nuts together. Then when it comes time to torque the oil filter adapter, stick the bolt head in the adapter and torque with a socket on the nuts.
You do have a Service Manual and a torque wrench correct? If not, go get'em as they will be the two most useful tools in your toolbox. Everything has a torque and everything should be torqued! You can find the proper torque for almost everything in the service manual, along with clear procedures for most anything.
If you connect the OTG sender in the cooler line as shown in the HD instructions you may not get a reading 'til the thermostat opens, which may take a while or never happen in cold weather. Some have complained that they never see the gauge move. The best location for the sender is the pan, and that can be easily done with a Napa #3220 x 6 x 2 (1/8F-3/8M) adapter. Jagg agrees, BTW, because the pan is where the oil goes after it circulates in the engine, so it gives the best indication of peak temperature.
There are plenty of threads on this subject here, so if you need more info do a search on "oil temperature gauge".
Thanks can you tell me if this is the correct part?
https://www.acehardwareoutlet.com/(3...SKU=2147006074
