ticking noise
My lifters made a lot of noise after a long run. after the run when the bike sat for about an hour, upon starting it sounded the engine was coming apart and would go away after about 1 min. Dealer checked the lifters and all, and Told Me the problem was the Oil pump alignment???????. Anyways that was last July, and the noise has not occurred since, I have a 08 Ultra.
Does it sound like one lifter or all? If all, it could be equipped with one of many aftermarket cams with steep acceleration ramps (e.g., Andrews). Do you know the bike's service history for maintenance and performance upgrades? What oil pressure does it run once warmed up at cruising speed?
ticking noise
the bike was purchased in feb it has v&h basic slip ons and a factory
breather so i put on a high flow breather and checked the codes on the fuelpack they are way different than the ones on the f/p web site for what i have on the bike i bought the bike from a local car lot so there is now way of knowing what else has or hasnt been done
ive always ridden ricers and could tel when something just wasnt right
and im sticking with my gut something is just not right
One thing that helps is a good quality synthetic oil. At your next oil change (or sooner) get Redline, Amsoil, or any one of a few others (search for oil threads) and it will quiet it down some.
Oil Pressure seems normal.
