Best spark plugs
Champion is OE supplpier for HD. Other brands may work, but compare the electrode and the cermanic and you will see the Champion is longer like the HD one, just sayin. I use NGK in everything else I own, if it was not for my EVO fouling the NGK out, I would have never stumbled on the Champion ceramic being longer.
An old wrench told me back in the 70's on my 1st Harley.. IF she's running good and starting good,, then don't mess with anything, just ride her..
I am with molsen on any internal benefits. If it fires, you are OK. However, in my long term life experience, NGK has the best outer finish. Same results in my outboard. You sure do not need a special tipped long life plug. Just change them ever 10K. Then you will not have any problem getting them out. I cannot see much difference in price in the NGK or Harley Plug.
Received 2,524 Likes
I think we get caught up in all this tech crap. They make a so-called better plug that cost 5 times as much and we THINK they are better. What are the real factual documented benefits? Fractional at best-maybe. How long have Harley's been running on stock copper plugs? 112 Years+. Change at regular intervals and use correct gap plugs that are recommended for the machine and I doubt you will go far wrong. Also, every dealer has them. No hunting all over. Change your oil/change your plugs/blow out or change air filter.Done deal.
