2008 SG Fuel Tank Removal Question
Hi everyone I need some help on this. I need to remove my fuel tank to route some wiring under it. I'm reading my service manual and the tank looks fairly easy to remove.
How much gas should I expect to drain from the tank and fuel line once I unhook the quick connect? The manual says there is a check valve in the fitting so the gas won't drain out of the tank, but I want to be sure I have a container big enough for any drainage. I will have a gallon or more left in the tank and don't want a major disaster in my garage. Thanks!
Location: CHILLIWACK B.C CANADA: have a u.s shipping adress
like the others said, the fuel supply will just drip a bit- do it with a rag under it. The bypass is the tuffy. clamp off each side and cut between the clamps. expect a little, again just use a rag. once the tank is off you can drain it the rest of the way. I bought a dry disconnect off ebay another member pointed out.
I installed wiring that required taking the tank off. Instead I took off all the fasteners and lifted it in the front with some cord tied around the grips. In the back I wrapped a small block of wood in a rag and wedged it underneath. You can get enough elevation to run wires without disconnecting everything, dripping gas and worrying about scratching the tank.
